student-loging avatar image
student-loging asked student-loging commented
Using Decide to make boat leave dock
Hello flexsim community,
I am trying to make a process where a boat arrives at the dock, a crane (robotarm) will unload the boat, and when the boat is empty it is supposed to leave the dock.
So far the boat arrives, is unloaded, and then just stands still when its empty and the crane is finished unloading. Appreciate all help!
Here is a link to the model:
Testfil for decide funskjonen.fsm
FlexSim 24.2.1
decide activity process flow
Felix Möhlmann answered student-loging commented
The Decide should check if the ship is empty, not the robot. You don't need (or should) write an "if" to the condition field. The expression you write there is inserted into an if-statement that is fixed in the code for the "Conditional Decide" option.
You refer to a non-existant table at various points in the model. I removed those in the attached model to not have constant error messages.
testfil-for-decide-funskjonen_1.fsm
· 3
student-loging avatar image student-loging commented ·
Thank you so much for the answer. Unfortunately my model will not run. Which non-existant table are you refering to? I have changed the decide function to the same as you. I'll attach my file once again.
Felix Möhlmann avatar image Felix Möhlmann student-loging commented ·
In the model you uploaded in your question a table "størrelse" is referenced in various places.
There is still a ")" at the end of the condition that needs to be removed. And you have to add the "Ship" label to the token and have it point to the ship object.
student-loging avatar image student-loging Felix Möhlmann commented ·
Thank you so much for the help :)
