berkowicz-k avatar image
berkowicz-k asked Felix Möhlmann answered
Choose Global Table Lookup by Parameter
I would like to use a staff resource where the staff is selected by global lookup table and the table used for lookup is attached to a parameter. For example if parameter1 is set to 1 then "Table1" is used and if parameter1 is 2 then "Table2" is used for staff lookup. How can this be done?
Any help is appreciated,
FlexSim 21.0.10
global tableprocesss flowresourcestaff
2 Likes"
If the table names are the same except for the numbering you can just put something like the following in to the table name field.
"Table" + string.fromNum(Model.parameters.StaffTable)
If the names differ more, I would suggest to edit the code directly and use a switch statement with the parameter value as the case value.
table-lookup-by-parameter.fsm
