juliategami avatar image
juliategami asked juliategami commented
Learning curve
How can I change processing times based on a learning curve?
I am running a rampup simulation on a line, and I want to assign a formula to the processing time of each station that represents this learning curve7. In this case, I want to use Y= A*X^B, where Y is the time to produce unit X, A is the time to produce the first unit (for example, 15 seconds), X is the cumulative number of units produced, and B is the logarithm of the learning rate divided by the logarithm of 2. In other words, as the operator produces items, each item would have a decrease in its processing time. Would it be possible to do this?
Thank you in advance!
FlexSim 24.2.2
processtimelearning curverampup
Felix Möhlmann answered juliategami commented
You can use the input statistic (current.stats.input.value) as X and enter your formula into the processing time field using the methos of the "Math" class.
https://docs.flexsim.com/en/25.1/Reference/CodingInFlexSim/FlexScriptAPIReference/Data/Math.html
· 10
juliategami avatar image juliategami commented ·
How do I apply input statistics?
juliategami avatar image juliategami juliategami commented ·
Could you help me with a practical example?
Felix Möhlmann avatar image Felix Möhlmann juliategami commented ·
The expression "current.stats.input.value" will return the total input of the object, which is the X in your formula. A would be a fixed factor and B the exponent in a Math.pow() function.
process-time-formula.fsm
