Patrick Cloutier avatar image
Patrick Cloutier asked Sam Stubbs commented
Container object does not connect to others when duplicated
The new container object does not automatically connect to other objects when duplicated either with a Parameter set on "Delete and Copy Group Members" or with Instances.
In either methods, the Container and its internal connections are duplicated but not the external connections.
See attached model for an example with Parameter.
Is this a bug or am I doing something wrong?
Container connections.fsm
FlexSim 25.0.3
connectionscontainer object
Sam Stubbs avatar image Sam Stubbs ♦ commented ·
This does in fact look like it could be a bug. I will let the developers know about this.
