hi all
I would like to know if there are any guidelines or considerations when making transparencies in SketchUp, because even though I have the same component in two parts of the shape, in some cases the transparency is shown and in other cases it is not.
in the image you can see how the component is visible before and after passing through transparency (gray panels)
I know that if I create transparencies in flexsim they have to be before the objects that are going to be seen through them in the object tree.
but for the case of shapes created in SketchUp how should it be done?
thanks for your help
