Elax Kot avatar image
1 Like"
Elax Kot asked Elax Kot commented
Reinforcement Learning to determine the optimal number of queues
I am trying to make a reinforcement learning process in Flexsim. In our system, the processor 1 and 2 is a lot faster than processor 3. When starting processor 1 or 2, the system ensures that at least one queue is empty. If all of the queues are occupied, then the item will be held before processor 1/2. I want to determine if there is a way for me to find out what is the required number of queues. This is a simplification of the process that I am trying to optimize. Preferably, I want to use reinforcement learning.
In addition, since each queue has a specific logic (allowing only certain kinds of items to enter, with a certain "weight limit"), is there a way to duplicate the queues without copying the flexscript over and over again? Thanks!
FlexSim 23.2.0
queuereinforcement learningconstraints
· 2
Joerg Vogel avatar image Joerg Vogel commented ·
@Elax Kot, is there a way? Add more 3D processes and check how utilization changes in relation.
A typical concept of object- oriented programming is inheritance.
https://docs.flexsim.com/en/25.1/Using3DObjects/WorkingWith3DObjects/UsingTemplates/UsingTemplates.html#what
You can search in online documentation by keywords. Sometimes you get answers. In this case it would be successful.
Elax Kot avatar image Elax Kot Joerg Vogel commented ·
Thanks! I will look into using inheritance with our codes.
Felix Möhlmann answered Elax Kot commented
You can add (equal) queue to a group and link that group to a model parameter. The option "Delete and Copy Group Members" will create as many copies of the first object in the group as the parameter states.
You can then run an experiment to see how many queues you need (for the upstream processors to never be blocked I assume).
Here's a basic example where the number of processors needed to not get any backlog in the queue is determined that way.
experiment-example.fsm
Another approach would be to not change the number of queues and instead assume an unlimited capacity. By measuring the maximum content you can then calculate how many queues would have been needed to fit all material.
While you say that this is a simplification and I am by no means an expert when it comes to Reinforcement Learning, I don't see how it could be applied here. An RL agent is meant to make decisions during the model run based on the state of the model. Varying the starting conditions is what the experimenter/optimizer is for.
· 3
Elax Kot avatar image Elax Kot commented ·
Thanks! Using experimenter with range is indeed quite useful and would probably work. An additional constraints that I have would be having to accommodate for the custom code that I have added in the individual queue. Each duplication of the queue will have a slight modifications with regards to the tagging when I use it to interact with a global table that tracks the capacity of the queues.
1. Items that enters a queue will trigger an update to a global table.
2. Items that leaves a queue will also trigger an update.
This is doable when I'm manually copying and editing the custom code in each queue. However, I have no idea how to do it when I'm modifying using the experimenter. Is there a way for me to modify the custom code depending on the queue index?
This would be something that I'm looking to solve as well.
I agree with your point about not using RL in this usecase. It does sound like an overcomplication as opposed to just using experimenter. Many thanks for your response again.
Felix Möhlmann avatar image Felix Möhlmann Elax Kot commented ·
If possible, I would make the differences in the code depend on labels on the object. Those can be set in the OnSet code of the parameter.
experiment-example_1.fsm
Elax Kot avatar image Elax Kot Felix Möhlmann commented ·
That'll work wonderfully. Thank you so much!
