yurii avatar image
yurii asked yurii commented
one agv with 40 different paths
I'm working on a system where I have 10 machines with 4 possibilities of path for each one ; so its 40 paths ; the system actually has 2 operators who do the transport ; i already did the simulation of that ; my study is on changing the operators with one agv (it can be possible cz the output time of each machine is totally different with the others)
My question is : does the only way to make the simulation is to draw the 40 different path or there is another solution
FlexSim 25.0.2
agvpathagvcontrolagvrouting
· 3
Felix Möhlmann avatar image Felix Möhlmann commented ·
Are the paths defined as a layer in a dwg-file? If so, you could try to automate the path creation through the Autodesk Interop Module by reading the coordinates from the dwg.
Hi @yurii,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
yurii avatar image yurii Jeanette F ♦♦ commented ·
Hi Jeanette ,
Sorry for my late reply ,
It actually worked for me :
and there is a video in your youtube channel about it :
https://youtu.be/7blayNVi8IY?si=QKX8JteYh4KBZ9t5
