Disconnecting DLLs in 25.0.3 doesn't work, did work in 25.0.2. Tried on 2 separate computers with the same result. Using the right click option in tree view that is available in dev mode.
Assuming you mean: diconnecting module dlls in the right-click menu of the tree appears to do nothing in 25.0.3. In 25.0.2, the tree view (and others) would suspend draw and release control of module dll files. :)
Thanks for pointing this out, we've added this to the dev list. The next bug fix should resolve the issue.
11 People are following this question.
