I HAVE ONE RESOURCE THAT FEED 5 MACHINES . PUTTING 5 PRODUCTS IN ONE MACHINE THEN MOVE TO THE NEXT ONE ; how could i make that
Hi @sekai,
Thank you for contributing to our community! We couldn't identify a maintained license or subscription linked to your account.
You may need to update your profile information to identify yourself as a license owner or their associate. Check out our article for how to ensure you receive timely support. If you update your profile comment back to let us know - we'll adjust the priority of your post accordingly.
If your current license is expired, please contact your local distributor to renew.
Hi @sekai,
It looks like this question may be part of a homework assignment or academic project. The professors who assign simulation modeling exercises using FlexSim expect that the academic integrity of their assignments will be maintained. In addition, we are supportive of Honor Codes or Pledges that regulate the behavior surrounding academic assignments.
I recommend reading our best practices page on the subject, which includes some resources that you should find helpful as you use FlexSim for academic purposes. I also highly recommend Dr. Allen Greenwood's FlexSim Primer, which was written specifically for students and professors.
You could try something like this, but it depends on how often you feed from the resource. In this case, it is always one item per machine every 10 seconds.
12 People are following this question.
How to Setup the source by an input value
How to control the inputs and outputs of a production line?
Why is my second source not creating any items?
how to use source to generate trucks as task executors to be loaded with containers ?
How to create a reject - source connection and sort through queues to find matches to combine?
