Venkyvenkat avatar image
Venkyvenkat asked Jeanette F commented
Change default x,y,z location of object when drag and drop object from library
Hi all, when I'm trying to drag and drop object from the library it's default z position sets as 0.5 changing manually 0.5 to 0 is ok for one or two objects if I'm placing more objects I have to set z position to 0 which takes lot of time. Can any one tell me how to set default z position to 0. Thanks in advance
FlexSim 24.2.2
utilizationthroughputmaterial flow
Hi @Venkyvenkat, was Aldo Martin del Campo 's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Aldo Martin del Campo avatar image
Aldo Martin del Campo answered Felix Möhlmann commented
First, you need to check that you are not overlapping with another object that is at Z = 0.5. Normally, the objects you add should be set at height 0. What you can do is place all the objects you want to set at Z = 0, let's say in Group1. Then, go to the script, write the following, and run it. Automatically, everything should be set to the height specified in the variable 'height'.
"Group Group1=Group("Group1");
double height=0;
for(int i=1; i<=Group1.lenght; i++)
Group1[i].location.z=height;
Felix Möhlmann avatar image Felix Möhlmann commented ·
Also check if the z-position of the grid is set to 0.5. That would also cause all objects to be placed at that height initially.
2 Likes 2 ·
