mark zhen avatar image
mark zhen asked mark zhen commented
Task assignment problem
I need to add a new logic to my model. When M10 completes production and transportation, I need to check whether there are still items in the BUFFER. If there are, I need to process the products in the BUFFER first. My current approach is to set up a checking mechanism, but it is not working effectively.
0221-1.fsm
FlexSim 23.0.15
proces flowtask logic
0221-1.fsm (10.9 MiB)
Jacob W2 avatar image Jacob W2 ♦ commented ·
Hi @mark zhen , was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Felix Möhlmann answered mark zhen commented
If I understand the flow correctly, then items moved into the buffer (red) wait until a machine is available anyway (orange). So the logic you added (blue) is currently creating a duplicate task, likely messing up the processing order down the line.
All you need to do is to give token whose item is in the buffer priority when pulling a processor. Add a backorder strategy to the list that orders the pullers (tokens) by a label value. Set some default value for that value on all tokens (orange). If the item is moved to the buffer, increase that label (blue).
· 26
mark zhen avatar image mark zhen commented ·
0221-1.fsm
SO I finished this problem?
0221-1.fsm (444.6 KiB)
Felix Möhlmann avatar image Felix Möhlmann mark zhen commented ·
If you remove your added logic and implement what I outlined in my post, yes.
mark zhen avatar image mark zhen Felix Möhlmann commented ·
I have a question now. I think my vehicle vacancy rate is very high! Is there something wrong with my logic in dispatching vehicles? My current need is to solve the congestion problem of M10. So I have observed that maybe my call is not timely enough? So how can I improve it?
