When importing external DB data into the FlexSim Table, is there a method of processing data noise removal inside the FlexSim? Or should I come in through a specific program?
Is there an efficient way?
Hi @SuhyeonK, can you give us some more information on what data noise removal looks like?
There is the Table Validation Tool, but I'm not sure this is what you're looking for. You could use this tool to find data that doesn't fit in some rules that you define and then update the data point or log that it has failed.
You can also query the Global Table to do something similar - find data that doesn't fit with what you're trying to use it for and do something to log or fix the erroneous data points.
I don't believe there is any specific data noise removal tool within FlexSim. If the above options don't help you with what you're trying to do (or they require too much effort than what they're worth), and if there is an easier way to fix the data prior to importing it into FlexSim, you might want to go that route.
10 People are following this question.
