KORLOY_KMH avatar image
KORLOY_KMH asked KORLOY_KMH commented
Can I edit object's tree node position manually ? ( into the new plane)
I realized I need to create a plane first, but I'm too far away. Can I manually edit the object's tree node position?
Here is an example of what I need to do:
As you can see, Processor_A isn't under Plane1. To move Processor_A into Plane1, please provide instructions on how to achieve this.
Thank you!
FlexSim 25.0.2
treenode
· 2
mary avatar image mary commented ·
Yes, It can be done. You can refer this Flexsim Documentation Tutorial Task 4.2 - Create Clones Using Copy and Paste.
KORLOY_KMH avatar image KORLOY_KMH mary commented ·
Thank you very much :)
Dhakshna avatar image
1 Like"
Dhakshna answered KORLOY_KMH commented
Hi @KORLOY_KMH,
There is an option called "Edit Selected Object" under the "View" button in the top main menu. Using that, you can achieve this.
Press Ctrl and select Processor_A, then highlight the Plane object, and finally, click the "Move to Highlighted" button.
KORLOY_KMH avatar image KORLOY_KMH commented ·
It's works. Thank you :)
