Gui Vaccaro avatar image
Gui Vaccaro asked Gui Vaccaro commented
How to prevent library's packedmedia from loading standard shapes and media?
is there a way to prevent the packedmedia node from a library from including standard shapes and media already available in FlexSim?
I have a couple of custom objects (one of them is a version of an Operator). As a consequence, the library's packed media node copies several standard shapes and media regarding the operator to the library file. That inflates the library from 6 MB to 64 MB.
Thank you.
FlexSim 25.0.2
user library3d shapespackedmedia
· 3
Logan Gold avatar image Logan Gold ♦♦ commented ·
Hey @Gui Vaccaro, can you give us something to help replicate the issue? I haven't been able to replicate it. If you can give us an example model and/or custom user library, and the steps to replicate what you are seeing - or even replication steps with a brand-new model - that will help us better identify the issue.
Jason Lightfoot avatar image Jason Lightfoot ♦♦ Logan Gold ♦♦ commented ·
Seems to happen for me:
packedMediaExample.fsl
Gui Vaccaro avatar image Gui Vaccaro Logan Gold ♦♦ commented ·
Hi, @Logan Gold , adding to @Jason Lightfoot 's comment, please see the attached library. You will see a few interesting things:
1- the operator shapes are all added to the packedmedia node even if deleted. Once one clicks reload media, they will come back to the library
2- I created two examples of a dummy queue with different shapes. The one stored in the root branch will keep the shape when the media is reloaded; the one stored in a sub-node and called via dropscript will loose its shape. This gets even worse if flowitems or objects bundled inside a container visual tool (e.g. conveyors) are the objects.
Here is another question related to problem #2:
https://answers.flexsim.com/questions/175021/save-packedmedia-for-flowitem-in-custom-library.html
Naamloos.skpUntitled(1).skppackedmediaproblems.fsl
naamloos.skp (43.4 KiB)
untitled1.skp (18.5 KiB)
