Hi Team,
I am using Fluid Library objects. I have to access the output port to change the value from 1 to 0.75. But when I am trying to access the output port using following code, it is not working.
Could you help me to resolve it?
Thank you!
Hi Team,
Thank you!
You are assigning the value of the node (1) to a treenode type variable. A number is not a node, so the result is null. Assign the node (removing the ".value") and then set its value.
Got it! Thanks!
Could we use the below code to aceess the node as well?
treenode OP = cellrowcolumn(list,1,1);11 People are following this question.
Order of events in Flexsim when Message trigger is used.
Separator - How do I split a work item and send to different output ports?
Object Reference to Object Connected to Output Port Using Port Number
input 1 output 1 and input 2 output2.
How can I connect operators to output port from a table in a dispatcher?
