There's a DP on top of the conveyor, and I made it generate at the DP point using the "PF" "create object" function, but it's still not flowing to the conveyor. Is there a way to make it appear in the DP and flow to the conveyor?
Items must enter a conveyor system through an Entry Transfer. Create an Entry Transfer at the DP by connecting some other object to the conveyor and deleting it afterwards. Then create the item in the Entry Transfer.
To be safe, the Entry Transfer should probably be either slightly ahead or behind the DP (compare the "Distance Along" property) depending on whether you want the DP to trigger or not.
11 People are following this question.
