dantasvagner avatar image
dantasvagner asked Jeanette F commented
Import Ressource's Travel Properties from a Global Table
I need to import speed, acceleration, and deceleration data for a resource (fields from Properties > Travel) from fields in a Global Table.
Normally, the Properties fields allow linking to cells in the Global Table using a pipette tool, but it appears that this is not working in this case.
Thanks in advance.
FlexSim 24.0.6
propertiesglobaltemps
Hi @dantasvagner, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Felix Möhlmann answered
You could use the a parameter table rather than a global table. It offers pre-configured options to set properties of objects in a group to the specified value.
If you want to keep using a global table you can use the same code in the Model Reset trigger to set the properties.
treenode reference = Group("GroupName");
double value = Table("TableName")[Row][Col]; Array members = reference.as(Group).toFlatArray(); string propertyName = "MaxSpeed"; for (int i = 1; i <= members.length; i++) {     Object member = members[i];     member.setProperty(propertyName, value); }
