Joaquín MSV avatar image
Joaquín MSV asked Joaquín MSV commented
Restrict License Allocation on Specific Client - FlexNet Publisher
Hello all,
I have a license in a server in my company that is configured like the general manual explans (lmadmin). That license can be used concurrently with whatever PC that is in the same VLAN or have access to the virtual server (via firewall rules). So far we have worked like this, with the inconvenience that whoever that has configured the server address in their FlexSim installation, can get the license as long as he's the first opening the program on a given moment.
My question is if in the tool suggested by FlexSim to allocate licenses (lmadmin, FlexNet Publisher), is there a way of tracking who connects, creating a list of validated users, etc. I don't see anything in the documentation or playing around with the UI of FlexNet.
We are planning to add more concurrent licenses and a proper control is needed within the company.
Thanks in advance for your help.
FlexSim 25.0.2
licensing serverclientflexnet
Joerg Vogel avatar image Joerg Vogel commented ·
@Joaquín MSV, I had work with LM_PROJECT. It is an attribute inside an opt license file to manage, grant or restrict access to concurrent licenses on a server. Each client create a user variable in windows system calling LM_PROJECT. The value must match with the value in option file.
File name: flexsim.opt
INCLUDEALL PROJECT WISE20112 #grant all features
# grant only some features
INCLUDE dragdropconnect:VERSION=5.1 PROJECT WISE20112
INCLUDE expertfit:VERSION=5.1 PROJECT WISE20112
INCLUDE compile:VERSION=5.1 PROJECT WISE20112
the value is in this example "WISE20112".
VERSION parameter is optional
https://answers.flexsim.com/articles/49019/license-model-client-activatable-aka-standalone.html This link leads you to an article, which includes a link to flexera FlexNet manual.
Ben Wilson avatar image
1 Like"
Ben Wilson answered Joaquín MSV commented
Hi @Joaquín MSV,
As Joerg suggests, an Options file can do what you specify in your title: restrict license allocation by client PC.
If you search this community for "options file" you will find several Q&As that could suggest ideas how to use the options file to accomplish your goal. Here is a good one:
Using the options file on a license server - FlexSim Community
Not every bit of syntax in every Q&A will be good, so cross reference against the actual documentation found at chapter 13. Managing the Options File in the FlexNet Publisher License Administration Guide.
· 7
Joaquín MSV avatar image Joaquín MSV commented ·
Hello @Ben Wilson and @Joerg Vogel,
Many thanks for the guidance. Finally following the manual for option file I've been able to use the following structure:
GROUP flexsim_users John Anthony William
INCLUDE_BORROW flexsimlicensecode25.0 GROUP flexsimusers
With this I can set which users can take the license, excluding all others. I still have to investigate on how to use the option MAX_BORROW_HOURS to limit the use of it by user. Do you have any example regarding this? Thanks in advance.
Joerg Vogel avatar image Joerg Vogel Joaquín MSV commented ·
@Joaquín MSV, Borrowing is a feature for a transfer of a license for some time. It is like an installation as a standalone license. The server license must allow such a feature.
You control on a concurrent server the hearbeat (timeout maximum 1 hour). It is a time interval which grants a license. And it must be updated within this interval to be granted further on.
Joaquín MSV avatar image Joaquín MSV Joerg Vogel commented ·
Hello @Joerg Vogel,
I tried the option of only INCLUDE instead of INCLUDE_BORROW, but didn't work. Also I didn't find any info regarding the timeout you coment in the documentation (INCLUDE_BORROW).
I have a concurrent license, which would we the proper way to proceed then? Considering my goal is to have the same concurrent behavior than before (no options applied) but restricting the users.
Thanks in advance.
