Is there an easy way to write or export data from an ItemList to Excel? I don't see it working using the Export to Excel tool.
Hi @Jason Merschat, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Hello @Jason Merschat,
You can export tables to excel, so if you query the list and clone it to a table then you can export that table.
string directory = modeldir(); string filename = filebrowse("TestBook1.xls","Excel Files",directory); excelopen(filename); excelsetsheet("Sheet1"); Table Result = Table.query("SELECT * FROM ItemList1"); Result.cloneTo(Table("GlobalTable1")); excelexporttable("GlobalTable1",1,1,10,2); excelclose(1);
10 People are following this question.
How to export the turn time stats for each arriving truck to an Excel sheet in FlexSim CT ?
How can a write values to a Global Table?
How can I export some tables to excel with tirggers commands?
flexsim live data to another program (excel, note pad, the web)
How do I export a table with all the label values for each patient?
