Sebastián Cañas avatar image
Sebastián Cañas asked Sebastián Cañas commented
Export All Dashboards to CSV using FlexScript
Hi all,
I'd like to replicate the command Export All Dashboards to CSV using a button. How could I do it using FlexScript?
Thanks!
FlexSim 25.0.2
flexscriptcsvdata export
Logan Gold avatar image
1 Like"
Logan Gold answered Sebastián Cañas commented
The code for "Export All Data to CSV" uses a function_s command:
treenode focus = node("..>viewfocus+", ownerobject(c));
function_s(focus, "exportData", 1);
You could do something similar, but you need an open/active Dashboard to do it, like this:
treenode AnActiveDashboard = views().find("active>Documents/Dashboard/1+");
if (AnActiveDashboard != NULL) {
    function_s(ownerobject(AnActiveDashboard), "exportData", 1);
But if you are putting this in a button on a Dashboard, that will guarantee there is an active Dashboard.
Also, since it is a function_s command, there is no guarantee it will work in future versions of the software.
Sebastián Cañas avatar image Sebastián Cañas commented ·
Thanks! @Logan Gold!
zacharyh avatar image
1 Like"
zacharyh answered Sebastián Cañas commented
You can try creating a button in Dashboard and then adding the following custom code to the "OnPress" parameter for the button.
treenode link = node("..>objectfocus+", c);
/**Custom Code*/
Object current = ownerobject(c);
Array tableNames;
for (int i = 1; i <= Model.find("Tools/StatisticsCollectors").subnodes.length; i++){
tableNames.push(Model.find("Tools/StatisticsCollectors").subnodes[i].name);
for (int i = 1; i <= tableNames.length; i++) {
string tableName = tableNames[i];
//Make sure that there is a file named "Model Run Results" within the same directory as the FlexSim Model.
string fileName = modeldir() + "Model Run Results/" + tableName + ".csv";
Table.query("SELECT * FROM [" + tableName + "]").cloneTo(Table("GlobalTable1"));
exporttable(Table("GlobalTable1"), fileName, 1);
Hi @zachary.h,
Thanks for your answers, however it would work only for Statistics Collectors and the command consider also Chart Templates.
