How can I create 10 flowitems per week at source ?
You do this in a Date Time Source in Process Flow. A exiting token creates in in Create Object activity an item in your model. Then you move item into a 3D Object.
10 People are following this question.
How to Setup the source by an input value
How to control the inputs and outputs of a production line?
Why is my second source not creating any items?
how to use source to generate trucks as task executors to be loaded with containers ?
How to create a reject - source connection and sort through queues to find matches to combine?
