Does anyone know if it is possible to obtain a map of the route taken by the train?
If you're referring to an AGV on an AGV path, you could try out Jason's solution of Heatmapping the route to see where it goes. You could also potentially use Logan's answer here about debugging AGV routing.
11 People are following this question.
