Begoña Espiñeira avatar image
Begoña Espiñeira asked Jeanette F commented
OnReset - Module bug
I have created a module where I save the reset trigger here: maintree().find("project/events/OnResetModel/GMM_OnResetModel")
I added to the code:
print("ResetOK"); at the begining of the code
print("ResetDONE"); at the end of the code
Moreover, I added another print inside of an user command inside of the code GMM_OnResetModel : print ("Executing GMM_updateViewSettings"); to check that the code inside of the reset is executing all the user commands correctly.
If I close flexsim and I open a new model where I use my module this is the behaviour when I click reset: 1738070485242.png
I obtain this but my users command were not executed so all the code written in the Reset was not executed.
If I go to my node and I build node as FlexScript I get this :
This means that my Reset command is working well.
I built the node and saved my module again, but the same problem is happening, somehow the module doesn't save it built? I could add some code to build that node when I install the module but it doesn't make sense for me...
If I don't build the node, I found another way so that my reset works well:
1. Open new model and install module
2. Reset model:
1738070485242.pngReset doesn't work
3. Save the model and close flexsim
4. Open the model and reset
Now the reset command works, I guess the saving operation is doing something so that this node works properly, as the build node operation.
How can I save a module that has the command working when I create a model? I would really appreciate some help.
Begoña Espiñeira Sicre
FlexSim 24.2.1
modulesonresetbuildnodesavingmodule
· 2
Hi @Begoña Espiñeira,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Please also share the module.
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question.
