I get this problem when i run flexsim_env.py
Hey Mohamed,
It looks like the port FlexSim uses for communication with your Python script is already in use. Try closing any other programs that might be using it and run your script again.
If that doesn’t work, restarting your computer could help free up the port.
And if the issue persists, you might be able to check which program is using the port through PowerShell.
Let me know how it goes!
12 People are following this question.
