cyc avatar image
cyc asked Felix Möhlmann commented
How to create a special event or alternative to trigger this?
Hello experts,
I hope you're doing well.
I’m trying to track the utilized time of an operator because they occasionally need to perform other tasks. Specifically, I’d like to create an event that triggers when the utilized time for Operator1 reaches 10 seconds. And here's my question model: 0119_model.fsm
For example, I was considering using a condition like this:
getstat(Model.find("Operator1"), "State", STAT_TIME_AT_VALUE, 0, STATE_UTILIZE) == 10.
However, I’m not sure if it’s possible to achieve this using a FlexSim function. I’ve read the manual about "User Events," but those seem to be time-based triggers, which doesn’t align with the logic I’m aiming for.
Is there a way to accomplish this in FlexSim? Or is there another approach you’d recommend for tracking and triggering events based on an operator’s utilized time?
Thank you in advance for your guidance!
FlexSim 24.2.2
triggerevent
0119-model.fsm (32.9 KiB)
Joerg Vogel avatar image
1 Like"
Joerg Vogel answered Felix Möhlmann commented
You can do this in process flow. Event triggered source that creates a token when a utilize state starts, a delay activity for a waiting time and a decide activity to check, if there happened a second utilization during your waiting time. If a second event to utilize your object begins you find a token waiting in delay activity.
Felix Möhlmann avatar image Felix Möhlmann commented ·
Another option would be to use a kinetic tracked variable to track the utilized time. When the state changes set the rate of the variable. An Event-Triggered Source in Process Flow can then trigger upon the variable reaching a given threshold.
0119-model_1.fsm
0119-model-1.fsm (34.6 KiB)
