Leandro Meirelles avatar image
Leandro Meirelles asked Jeanette F commented
Query array label issue on Acquire Resource
I got 3 Machines, each Machine has a label (.numMachine) containing an integer 1, 2 or 3. Ex: Machine1.numMachine = 1.
I got a box (flowitem), storing an array label (.numMachines) containing the number of the Machine that it was processed. Ex: Box1.numMachines = Array[2]: {1,2}.
So now i want to Acquire a new Machine for the box to be processed, but can't be the same that already was processed by, so if my box was processed by Machine1 and Machine2, i want to acquire Machine3.
How can i write a correct query logic?
FlexSim 24.2.3
queryarray
Hi @Leandro Meirelles, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Joerg Vogel avatar image
Joerg Vogel answered Felix Möhlmann commented
Have you tried to use:
NOT IN
followed by an inserted array clause?
Felix Möhlmann avatar image Felix Möhlmann commented ·
"Pulled" and "token" are not valid keywords in the query. The thing that is queried can be accessed through "value" (though any text that has no other meaning will automatically be interpreted as a label on the value). Other parameters can be passed into the query through the use of "puller". In an Acquire activity the puller is always the token (in Pull from List the user can specify the puller).
So the query should be
WHERE numMachine NOT IN puller.item.numMachines
