ola avatar image
ola asked Jeanette F commented
Process flow- Work of two operators alternately, one after the other
I'm creating a production process in Flexsim 23. I'm having trouble setting up a process flow to have two operators perform the same action one after the other, in what I call a “chase scenario.” Should I make two separate windows or one common window? If one common one, how to designate that Op1 and Op4 will perform all set tasks in sequence.
Part of the process flow below, where they work separately, and the idea would be for them to take turns performing this tasks, one after the other.
Thnak you in advance for support and all ideas.
FlexSim 23.1.4
process flowoperatorstask sequencing in process flow
· 3
Felix Möhlmann avatar image Felix Möhlmann commented ·
If you haven't already done so, I would suggest you start by working through the shared assets and task logic tutorials. Those should get you started on how to approach building your logic.
https://docs.flexsim.com/en/23.0/Tutorials/ProcessFlow/Tutorial1UsingSharedAssets/UsingSharedAssetsOverview/UsingSharedAssetsOverview.html
https://docs.flexsim.com/en/23.0/Tutorials/TaskLogic/Tutorial1TaskLogicTools/TaskLogicToolsOverview/TaskLogicToolsOverview.html
Hi @ola,
Thank you for contributing to our community! We couldn't identify a maintained license or subscription linked to your account.
You may need to update your profile information to identify yourself as a license owner or their associate. Check out our article for how to ensure you receive timely support. If you update your profile comment back to let us know - we'll adjust the priority of your post accordingly.
If your current license is expired, please contact your local distributor to renew.
Hi @ola,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
