Hello, any reasons why this happens?
Should not this command return Array[0]? I.e., why is the length 1?
If you split a string that doesn't contained the passed in delimiter it will return the original string. In your example, the empty string is returned so the array has 1 entry (an empty string). Any string that you split that doesn't contain the delimiter will have the same result:
string("Test").split(",") returns Array[1]: [Test]
7 People are following this question.
