hikel avatar image
hikel asked hikel commented
Set Loading time when loading boxes
I would like to set different loading time for each Part Number based on global table (if part is in global table take it if not take a defaults number)
I tried using task delay as loading time and doing look up for part but the fork(lifter) keeps going up and down for each box picked. the only way fork is working properly is setting loading time in 3D object. is there any way to get label from process flow to 3D object or if there is any other solution I can do to get this one working. here is model loading_1.fsm
FlexSim 24.2.2
processs flowpickingloading time
loading-1.fsm (102.9 KiB)
Felix Möhlmann answered hikel commented
You can just read from the table in the load time field.
(If the "PartNumber" label exists on the item, use that to read a time from the table, otherwise return 0)
· 4
hikel avatar image hikel commented ·
Thank you @Felix Möhlmann
hikel avatar image hikel hikel commented ·
@Felix Möhlmann just a follow up question I am getting this error I know the part is not in the list normally it should return 0 but it is not working properly. I tried reversing the condition still the same problem.
FlexScript exception: 1/006 is not a valid row name for Global Table "Loadingtime" at MODEL:/Forklift8>variables/loadtime at line 8
Felix Möhlmann avatar image Felix Möhlmann hikel commented ·
The code I posted only checks if the label exists and is not 0. "1/006" is not, so it will throw an error if that header does not exist in the table.
Checking if a row header exists would require a for-loop. If you copy the headers into a separate column, you could first use 'Table.getRowByKey()' to check if a row with that value exists. If yes, return the time from that row. If not, return 0.
