Przemyslaw Pasich avatar image
Przemyslaw Pasich asked Jeanette F answered
Buggy bundle + importtable() interaction
The issue happens when importing a .csv using importtable() into a table that is defined to be a bundle: if the first row contains an empty string, the whole column gets disregarded completely and the import ends prematurely.
The expected result:
The achieved result:
The issue does not occur if the table is NOT a bundle type.
I am attaching a dummy model that recreates this issue + a sample CSV:
missing_col_when_importing_CSV_to_bundle.fsm
sample_csv.txt
Right now the workaround is to modify the .csv as a text file using fileopen() and replacing all the empty values in the first row with a dummy string value (e.g. " "), but can you please fix the issue in some future release of FlexSim so that importing to a bundle table and a non-bundle one behaves consistently?
FlexSim 24.2.0
csvimporttable
· 2
Nil Ns avatar image Nil Ns commented ·
It looks like a bug.
As a workaround, you can import without using the bundle and then change to that using a code like this:
missing-col-when-importing-csv-to-bundle.fsm
treenode selObj = Model.find("Tools/GlobalTables/Bundle_tbl");
createview(gets(guifocusclass(selObj)), nodetopath(selObj), "");
treenode view = views().find("active>Documents/Table").last.find("+/../../..");
function_s(view.find("/TableView"), "changeBundleData");
repaintview(view.find("/TableView"));
Table tbl = Table("Bundle_tbl");
string file_path = filebrowse("*.csv;*.txt", "CSV files", modeldir());
importtable(tbl, file_path, 1,0,",");
Przemyslaw Pasich avatar image Przemyslaw Pasich Nil Ns commented ·
Hi Nil, thanks for the workaround! Yours is a good one especially when you cannot edit the source CSV file. I'll keep it in my notes
Jeanette F avatar image
Jeanette F answered
This has been submitted to the development team for further investigation
