Ankur A3 avatar image
Ankur A3 asked Arun Kr answered
How to tackle -ve values from distribution without impacting mean value?
Hi Team,
I observed that whenever lognormal distribution is throwing negative values, it is picking the 0 value for repair time which is not possible in real system.
I would like to filter the 0 values from the table. But my concern is that it will impact the mean value of distribution. What are the other ways to handle this problem?
Breakdown_Count_Reps.fsm
Thank you!
FlexSim 25.0.0
distributionvaluesnegative
Arun Kr avatar image
Arun Kr answered
Try avoiding -ve or zero values in the MTTR value by modifying the code using a while loop.
double repairTime = -1
while (repairTime <= 0) {
    repairTime = lognormalmeanstdev(84.13, 110.3, getstream(current));
return repairTime;
If this is not is acceptable try some minimum repair time when the repair time becomes less than or equal to zero.
double repairTime =lognormalmeanstdev(84.13, 110.3, getstream(current));
if(repairTime <=0)
   repairTime = minRepairTime;
Regards,
Arun KR
