hby avatar image
hby asked Logan Gold commented
AGV Loop
how can I model AGVs 1, 2, 3, 4, 5, and 6 to operate only in the first loop, and AGVs 7, 8, 9, 10, and 11 to operate only in the second loop?
Also, I want blue boxes from 'Load 1' to be unloaded in the queue 'Unload 1' and red boxes from 'Load 2' to be unloaded in the queue 'Unload 2'.
Thank you in advance!
test tuto workflow.fsm
FlexSim 24.2.3
agvloopworkflow
Logan Gold avatar image Logan Gold ♦♦ commented ·
Hi @hby, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Felix Möhlmann answered
If each processor has a fixed then just don't use the "ItemsReadyForDelivery" list and instead go back to the default "First Avaiable" option in the Send to Port field of the processors and deactivate the "Pull" logic on the output queues.
With this change in place the AGVs should already stay in their loop as long as there is material to load. Because when an AGV loads to capacity it will drive directly to the nearest unload location while ignoring the NextWorkPoint loop.
In this case there is also only one control point with multiple outgoing connections, so the issue could be solved by adding a special case for that CP.
A more complete solution is to implement a second separate NextWorkPoint loop. Add another connection type with the same settings.
Build a separate loop out of those connections. Then add a second AGV template and move the vehicles for that second loop over there. Finally, change the list reference of the NextWorkPoint list to match the newly added connection type.
test-tuto-workflow_1.fsm
