David Lam avatar image
David Lam asked Jeanette F commented
Montacargas para Depositar Cajas Específicas en Estanterías
Estoy trabajando en una simulación en FlexSim donde tengo un montacargas que necesita realizar una tarea específica:
  • Depositar exactamente 2 cajas en una primera estantería designada.
  • Luego, mover a una segunda estantería y depositar allí otras 2 cajas.
  • Y una vez que termine de poner cajas en estanterias seleccionadas. Que el montacargas pueda moverse a cualquier estanteria. Y llenarlas
FlexSim 23.0.15
warehousing
· 3
Aldo Martin del Campo avatar image Aldo Martin del Campo commented ·
2501_ESTANTERIAS_MONTACARGA.fsm
Hi, here is a model where you can prioritize the first two boxes in each shelf with process flow. I'm not sure if this model helps. If you have other ideas, please let me know.
Hi @David Lam,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
Hi @David Lam,
Thank you for contributing to our community! We couldn't identify a maintained license or subscription linked to your account.
You may need to update your profile information to identify yourself as a license owner or their associate. Check out our article for how to ensure you receive timely support. If you update your profile comment back to let us know - we'll adjust the priority of your post accordingly.
If your current license is expired, please contact your local distributor to renew.
