Ryusuke T avatar image
Ryusuke T asked Jordan Johnson answered
The AGV with the trailer attached goes through the T-junction
If an AGV with a trailer attached has a slight incline on the transport path before the T-junction, it will not be able to turn right at the T-junction properly.
I have confirmed that if I adjust the inclination issue, the car can turn right normally, but I would like to maintain the inclination if possible.
What kind of measures can be taken?
Trailer problem.fsm
Trailer problem workaround.fsm
FlexSim 24.0.4
agv trailer
Ryusuke T avatar image Ryusuke T commented ·
Since I posted at the end of the year, my post may have been overlooked. Could you please check this post?
Jordan Johnson avatar image
This looks like correct behavior to me. The issue is that the slanted path creates a larger change in rotation for the AGV. Note the AGV's rotation when it is on the slanted path:
When the AGV gets to the next path, its rotation needs to be 0 in order face forward along that path. The default AGV settings indicate that if the AGV changes rotation by more than 91°, it will need to reverse directions. The solution is to update the AGV settings:
A value higher than 96.98 will resolve the issue. However, you'll probably want a more permissive value, like 120 or even 179.
