Lucas_Prata avatar image
1 Like"
Lucas_Prata asked Logan Gold commented
Insert data into the property table through a global table with Excel Import
I need to link the property table with Excel to change conveyor properties. When I use a global table with Excel import, I cannot update the property table. Could you tell me how I can do it?
Thanks in advance,
Lucas Prata
FlexSim 24.0.6
global tableexcel importproperty table
Logan Gold avatar image Logan Gold ♦♦ commented ·
Hi @Lucas_Prata, was joaopedrostefani's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
joaopedrostefani avatar image
1 Like"
joaopedrostefani answered Lucas_Prata commented
Hello Lucas, how are you?
There is more than one way to perform this import. One possible method is to import the data from Excel into a Global Table and update the Property Table using the “Update On Reset” option.
To do this, first, create an import of the data from Excel into FlexSim.
Next, in the properties of the Property Table, click on the “Update On Reset” option.
Ensure that the Excel data is in the desired format, either as numbers or text (for instance, conveyor speed should be a number).
After adding the fields to be updated in the Property Table, click on Generate in the Property Table properties to create the update query.
Finally, in the properties of the Property Table, in the Update Query field, replace the line:
To: ON Obj.Object = Model.find(Src.Object)
This replacement will locate the reference objects imported from Excel.
Every time you click Reset, the settings will be updated. Examples of the model and the input spreadsheet are attached.
PropertyTable_Inputs.xlsx
FX_Suport_18050477201.fsm
I hope this procedure meets your expectations. If you have any questions, we are at your disposal.
Lucas_Prata avatar image Lucas_Prata commented ·
Thank you very much @JoaoPedroStefani! It worked perfectly.
