Tim avatar image
Tim asked Joerg Vogel commented
Advice on software operability
In the process of using the software, when I want to rotate the axis direction of an entity, I cannot easily know the default coordinate direction (based on the axis of the model floor), so I need to add a new entity to judge the correct rotation direction, which is too painful. Could you please add a shortcut display of the axis in the lower left corner of the view? This can greatly promote the sense of experiencetest.png
FlexSim 25.0.0
suggestioncentervisualcenter
Joerg Vogel avatar image Joerg Vogel commented ·
You can observe coordinates a mouse pointer does in a workspace. You find it left bottom border of FlexSim program window.
You place a new object and highlight it. You see coordinate handles, which follow a common rule red = x; green = y, cyan or blue = z.
As I remember this feature existed in some previous versions of FlexSim.
