MathchingTokenLabelWithModelLabel-01.fsmIs there a way take ProcessFlow create object labels matching the token label and can be used later by 3D model? also if there is a way to it in the other way around?
Hi @Sam , was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Assigning labels to tokens or items in the Create Objects or Assign Labels activity is always done one by one. There is currently no function to copy over all existing labels at once.
What you could do is to not copy the labels but instead write a reference to the token to the item. This would allow you to reference the token and thus the labels on it through the item. Effectively having the item use the labels on the token.
12 People are following this question.
