I am using flexsim webserver with the following settings. The version of the webserver is 24.1.0.
As you can see in the gif below, the webserver itself is working, but I am having trouble uploading the model. Can you help me?
# This file needs to be in the same directory as flexsimserver.bat General: Flexsim Program Directory: %PROGRAMFILES%\FlexSim 2024 Update 1\program Model Directory: C:\Users\username\Documents\FlexSimWebServerModelDirectory Port: 8080 Reply Timeout (milliseconds): 10000 Max Instances (of Flexsim): 8 Max Threads Per Instance: max Ignore Auto Save Files: yes Headless Instances: yes Remote Operations (security hazards): Model Uploading: yes Model Downloading: no Model Deleting: no Max Upload Size (bytes): 10000000 Jobs: Flexsim Data Directory: %AllUsersProfile%\FlexSim\FlexSim24.1 Max Job Queue Length: 100 Max Job Timeout (seconds): 3600 Windows Authentication: Use Windows Authentication: no Restrict UserGroup Directories: no Active Directory: url: ldap://dc.domainName.com baseDN: dc=domainName,dc=com username: specialUser@domainName.com password: password Session: Enable: no Secret: flexsim secret Max Age (seconds): 3600
Thanks in advance.
