I have flexsim 2024 update 1, I am trying to create live connection with NVIDIA omniverse using live Omniverse connector in Flexsim, but when I click on "Create" nothing happens - means it is not creating any live session for omniverse.
Did you put in a name for the session? Have you saved the usd stage to the location in the nucleus server/ using the 'ominiverse:' style url for the usd stage file?
But I have not saved the USD stage to nucleus server, I kept it in my local laptop.
Do I have to save on nucleus server for getting live connection?
Try getting the url link to the file from the Nucleus Server interface and paste that as the USD stage path. You can run the Nucleus server locally and access it through the Omniverse launcher.
On Nvidia page they mentioned deprecated requirements. But I think, you need still a hardware configuration able to render scenes and stages. Raytracing capability is necessary. Maybe you need in a way a NVIDIA supported graphic card.
Hi @SHR5987,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
Hi @SHR5987, Have you been able to solve the problem?, is something similar happening to me.
14 People are following this question.
Loss of connection in USD file and visualization query on Omniverse
Can the Machine Appearance in FlexSim Be Modified Using .usd Files?
why my flexsim does not have omnivere connector?
FlexSim model disappears after exporting to Omniverse with USD Stage
Object displacement after integrating FlexSim with Omniverse.
