Found a bug when joining two straight paths in AGVs using the Join paths tool. The path class of the (curved) path is set to Straight instead of Curved as default. The following screenshot shows it:
Thanks!
Thanks!
Hi @Jesús, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Hello @Jesús,
This has been submitted to the developers for further investigation.
And this bug is still not fixed in 25.0.2. @Parker S could you please increase the priority of fixing this bug ?
When you join 2 straigth paths in 24.0.8, the path class of the newly created curved path is a curved path. Correct.
When you join 2 straigth paths in 25.0.2, the path class of the newly created curved path is a straight path. Wrong.
There has been no progress from this ticket for the development team. I have requested for the issue to be escalated.
12 People are following this question.
