ksugai avatar image
ksugai asked Jason Lightfoot answered
AGV Customization Delegate - Control point at an intersection causes error
NavigationError.fsm
In the attached model, a navigation error occurs when the AGV is given a task to go to CP3.
(If the ShouldBuildCustomRoute is set to 0, the error does not happen.)
Please tell me the cause.
Thank you in advance.
FlexSim 24.1.0
controlpointintersectionagv customization delegatenavigation error
navigationerror.fsm (35.4 KiB)
Jason Lightfoot avatar image
This looks like a bug - if the paths and control point are not colocated it works as expected - we'll create a case in the issue tracker.
Note that the documentation recommends that you use the AGV Properties option for custom path weighting, which is believed to satisfy most requirements.
