Lawrence Liang avatar image
Lawrence Liang asked Lawrence Liang commented
How can I use storage.system class to call findslot method by dll maker?
Now I want to use dll marker to realize most business logics, but I can't find assignslot and findslot methods in FlexsimFuncs.h file.
How can I use storage.system class to call findslot method by dll maker before UNLOAD Task as below?
treenode ts = createemptytasksequence(rmg, 0, 0);
inserttask(ts, TASKTYPE_UNLOAD, unit, yardBlock,0,0,0,0);
dispatchtasksequence(ts);
FlexSim 24.1.0
c++dll makerstorage
Hi @Lawrence Liang, was Jordan Johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Jordan Johnson avatar image
Jordan Johnson answered Lawrence Liang commented
I don't think you can access the storage system through the dll maker. From the manual:
Generally you can only access FlexSim's global user commands, not FlexSim's dot syntax methods and properties.
https://docs.flexsim.com/en/24.1/Reference/DeveloperAdvancedUser/ConnectingToExternalCode/ConnectingToExternalCode.html#building
The Storage system API counts as "dot syntax" as dots are used to access methods and properties:
Storage.system.findSlot()
So you can't use that API from the DLL maker.
However, you can access that API from the Module SDK:
https://docs.flexsim.com/en/24.1/Reference/DeveloperAdvancedUser/ModuleSDK/ModuleDevelopment/ModuleDevelopment.html
The FlexScript API is loosely related to the C++ API. C++ handles namespaces a little differently, and sometimes patterns in FlexScript aren't available in C++. So the line of code you need in the module SDK looks like this:
auto slot = FlexSim::StorageSystem::getInstance()->findSlot("WHERE ...");
· 3
Lawrence Liang avatar image Lawrence Liang commented ·
Thank you for your prompt feedback!
Now, I'm try to write a method to solve it.
Please check following these codes,
void FlexSimTools::assignRackSlot(treenode rack, treenode parent,treenode item, int baySeq, int rowSeq,int tierSeq)
treenode rootNode = model();
string rackName = getname(rack);
string parentName = getname(parent);
string itemName = getname(item);
string strNodeAssignedSlot = "/" + parentName + "/" + itemName + ">stored/1/assignedSlot/1";
treenode nodeAssignedSlot = findTreeNode(rootNode, strNodeAssignedSlot);
if (nodeAssignedSlot == NULL)
treenode node1 = node("/" + parentName + "/" + itemName + ">stored", model());
treenode node2 = nodeinsertinto(node1);
nodeadddata(node2, DATATYPE_STRING);
setnodestr(node2, "assignedSlot: size = 1,");
treenode currentSlotNode = nodeinsertinto(node2);
setnodename(currentSlotNode, "currentSlot");
nodeadddata(currentSlotNode, DATATYPE_NUMBER);
setnodenum(currentSlotNode, 0);
treenode node3 = nodeinsertinto(node2);
setnodename(last(node2), "assignedSlot");
nodeadddata(node3, DATATYPE_NUMBER);
setnodenum(node3, 0);
nodeinsertinto(node3);
nodeAssignedSlot = last(node3);
nodeadddata(nodeAssignedSlot, DATATYPE_STRING);
setnodestr(nodeAssignedSlot,
"/" + rackName + ">variables/bays/" + to_string(baySeq) +"/levels/" + to_string(rowSeq) + "/slots/1/slotItems/" + to_string(tierSeq));
Jordan Johnson avatar image Jordan Johnson ♦♦ Lawrence Liang commented ·
The code looks like you are trying to assign an item to a slot, but you are doing it without using the API. Try something like this:
if (slot) {
    StorageObject::Item* storageItem = StorageObject::assertItem(item);
    storageItem->assignedSlot = slot;
Lawrence Liang avatar image Lawrence Liang Jordan Johnson ♦♦ commented ·
how can I use the API by dllmaker? Do you mean that I need to put allobjects.h into my C++ project? and set COMPILING_MODULE_DLL to C/C++->Preprocessor. After compiling, I found a lot of errors.
Lawrence Liang answered
I can't find class StorageSystem in flexsimdefs.h , Do you mean that I need to put allobjects.h into my C++ project? and set COMPILING_MODULE_DLL to C/C++->Preprocessor. After compiling, I found a lot of errors.
