Hi
I have a model where the separator has to split a single pipe into 5 pieces with 20 seconds as cycle time. The issue is I don't want 5 pipes after 20 seconds, instead, I need each pipe at intervals of 4 secs.I can use process flow to create objects on sub-flow but want to know if there is any easy method.
Thanks in advance
test.fsm
