poopatel avatar image
poopatel asked poopatel commented
Stop pull condition if downstream content is full
In the model Processor 1, 5, 6 are pulling parts from a list. What I want to do is stop the pull condition if Queue 5, 6, 7 are full (max content) respectively. I tried using triggers but while its closing and opening the ports its not stopping the pull condition by processor. I don't want a part to be waiting on processor.
FlexSim 23.0.0
pullconditional decidepull from list based on condition
· 2
Hi @poopatel,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
If your model contains sensitive information, you could first toggle your post as private using the "make private" option under your question's "gear" menu. Private questions are visible only to site moderators. You can also contact your local FlexSim distributor for phone or email help.
poopatel avatar image poopatel Jeanette F ♦♦ commented ·
Sorry i forgot to post the model
example_dummy.fsm
example-dummy.fsm (31.4 KiB)
Jeanette F avatar image
Jeanette F answered poopatel commented
Hello @poopatel
I added a condition on the pull from list that checks the queue content is below its max content.
When this condition fails the processor will not pull from the list. The processor will need to be prompted when to pull items again. To accomplish this, I added a trigger to the last processor to tell the processor to receive an item.
example-dummy_1.fsm
example-dummy-1.fsm (32.2 KiB)
· 5
poopatel avatar image poopatel commented ·
Thank you, it works!!!
Just one more query that I have is what if I am also pushing items in Queue 6 and 7 to a list and processor 2 and 3 will pull from that list will the logic still work ?? or do I need to change the location of trigger to tell the processor 5 and 6 to receive an item.
1709067312769.pngexample-dummy-1.fsm
Jeanette F avatar image Jeanette F ♦♦ poopatel commented ·
Your model did not attach can you try adding it again? I have an idea how to accomplish this
example-dummy-1.fsm (33.0 KiB)
