diego-rt avatar image
diego-rt asked diego-rt commented
How I can conect a python file with a flexsim model
Good night,
I have a problem with a FlexSim model. I want to connect a process flow with a Python file, where I have a solution for a linear optimization problem. I tried like you have in the next image, but I couldn´t get an answer.
In this picture, the first line is the file´s name, and the second one is the function´s name.
Can anyone help me, please?
Regards.
FlexSim 23.0.3
processs flowanswers.flexsim.cominteraction between flexsim and python
· 5
Jason Lightfoot avatar image Jason Lightfoot ♦♦ commented ·
Is it in the same folder as the model? Have you set the global preferences to the correct python version? Have you toggled the code as external? Have you put it in a user command? Is your custom code calling a user command? Which activity is calling it? Can you attach your files and model?
diego-rt avatar image diego-rt Jason Lightfoot ♦♦ commented ·
I can insert just the Python file. The Flexsim model is too large to send. In addition, I put both files in the same folder, and I selected a Python script in the FlexSim process flow.
If you believe you can help, please text me at my email address, dramatoja@gmail.com, so I can send you the FlexSim file. Here is the Python script:
MinCostFlow.py
I am very grateful for every help you can offer me; it is something important to me.
Thank you.
mincostflow.py (1.9 KiB)
diego-rt avatar image diego-rt commented ·
Here is more information about how I made my connection and why I do not consider this option a mistake.
Jason Lightfoot avatar image Jason Lightfoot ♦♦ diego-rt commented ·
You can't put flexscript into an external code function like that - you should from your custom code call a user command with parameters to pass to the python function.
I am not sure about how I should do it because I think I did it in the Python file attached before, if I understood well.
Jason Lightfoot answered diego-rt commented
Here's an example of how to call your Python module from a process flow via a user command and have the returned array added to the token as a label.
minCostFlow.zip
mincostflow.zip (28.7 KiB)
Thank you for your help! It was very useful.
