Rara Hasna avatar image
Rara Hasna asked Jeanette F commented
Parameters, group of objects, more than 1 output ports
Hello, on this model below I try to group an operator, processor, and queue in Plane 1 (reference: https://answers.flexsim.com/questions/130858/delete-and-copy-group-members.html)
The Processor itself processes all items and then separate them to 2 Output Ports by Item Types (I use Output > Send to Port > Port by Case):1706528470273.png
I already set the Plane as a Group and used it for parameters, but the problem is if I set the parameter value to 2, the item that went to Processor1_2 got blocked and couldn't send the item to Output Ports. If I see the Output Ports, the processor suddenly adds another blank output port as the first output port. I tried to delete it but every time I re-run it the blank output port just added by itself.
Can you tell me what's wrong with the model and help me to fix it? Thank you very much.
experimenter plane.fsm
FlexSim 22.2.0
groupsplaneoutput portparameter
· 4
Felix Möhlmann avatar image Felix Möhlmann commented ·
Looks like a bug to me. Copying the plane breaks one of the connections to the processor.
You can work around it by deleting the output connections of the copied processor in the parameter's "On Set" code before the new plane is connected to the 'outside objects' again. See line 28 below.
Rara Hasna avatar image Rara Hasna Felix Möhlmann commented ·
Hi, thank you for replying. I tried to delete the Output Ports on the copied Processor and follow your instruction to write the "On Set" code but it didn't change anything. Am I doing it right?1706533404341.png
Felix Möhlmann avatar image Felix Möhlmann Rara Hasna commented ·
Looks correct. In one test I also had problems getting it to work right away. Try deleting the second plane manually and/or setting the parameter to something other than 2 after you applied the changes to the code.
Hi @Rara Hasna, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Jason Lightfoot avatar image
Jason Lightfoot answered Jeanette F commented
As Felix say's, this does look like a bug - thanks for pointing it out. I'll send it to the developer team.
· 2
Patrick Cloutier avatar image Patrick Cloutier commented ·
This bug seems to not be solved because I have the same issue in 25.0.2: when using Delete and Copy Group Members in Parameters to duplicate a plane with objects on it, not all connections are copied. There are missing connections in the duplicates.
Jeanette F avatar image Jeanette F ♦♦ Patrick Cloutier commented ·
Hello @Patrick Cloutier,
Thank you for your comment. I am requesting an escalation for this issue.
