I want to complete the application of some performance indicators, as shown in the figure, but I cannot execute it smoothly. I would like to ask how to successfully reference these indicators.random-action-autosave_autosave.fsm
Hi @mark zhen , was one of Felix Möhlmann's or Joerg Vogel's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
To get the performance measure value, you have to execute the code in the "valueNode" of the performance measure value.
In this case, in order to work correctly, the code requires you to pass in the reference object as a parameter when executing the code.
You probably also want to place a 0s-delay in the Process Flow to get the performance measure value after the item has exited the queue.
You declare the "reference" variable twice. (You get an error telling you this when you try to apply/compile the code).
And you should only change the reference node after assigning the first value. Otherwise both parameters will obviously be set to the same value.
15 People are following this question.
