I can't handle this FlexScript exception in the attached model:Thanks in advance.
Hello @Joerg Vogel, thanks for your consideration.
I've uploaded the model again and a GIF for the error in case the model doesn't work properly again.
Current Layout_3.fsm
You have trailing whitespace in your entry for product type 10 in the "SKU" table. So any token that is querying for "Product type 10 " is not finding any slot items and the resulting label contains a NULL value which leads to errors in the subsequent activities.
In general you should make sure that a slot item was actually found before letting the token continue to activities that access this value.
Thanks, @Felix, for your feedback. It would be a great help for me if you elaborate on how you debugged it though.
15 People are following this question.
