How to give sequence numbers as Value in Triggers in DP? When the item passes get allotted to Sequential number in the Global table.
at queue1 in model, there is a strict increase of numbers by entering items to set a different unique name. You can easily use it for any other purpose.
Hi @krk, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
You can use this to add sequential numbers to your decisions point's trigger:
current.stats.output.value+1
Not sure what you're asking with respect to a global table.
Trying to use this but having and issue. everything just comes out with a number of 1.
16 People are following this question.
MassFlowConveyor - Decision Points & Triggers Help
how to count the number of flow items of certain item type in a model?
Label Values Conditional Decide - odd or even value
How to change destination of box on conveyor if destination is full
Is it possible to add more than one label with triggers to the same item?
