Vaibhav R3 avatar image
Vaibhav R3 asked Jason Lightfoot commented
How to change center of rotation?
requesting to share how to rotate a conveyor around its mid-point instead of one of its corners...thanks.
FlexSim 21.1.5
object rotation
Jason Lightfoot avatar image Jason Lightfoot ♦♦ commented ·
Hi @Vaibhav R3, was one of Jason Lightfoot's or Jordan Johnson's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
Jordan Johnson avatar image
Jordan Johnson answered
There isn't a straightforward way to do this, partially due to how the conveyors are designed.
You can write a script to rotate the conveyor. Note that this should only be done as part of building a conveyor system, not during the model run. The attached example model has two user commands you can use to rotate a conveyor about the middle Z.
RotateConveyorDemo.fsm
1 Like"
Jason Lightfoot answered
You could place the conveyor in a container/plane and rotate that instead.
